Thermoforming tray resistance
Hello Vijay Sir, Andy Sir & JK Sir,
I would like to confirm one point with you regarding the recently received thermoforming tray lot from the supplier.
The Point-to-Point resistance of the trays was measured in the range of 10^3 Ω, while the Point-to-Ground resistance was around 10^7 Ω as these trays are going to be used with trolley and workstation.
I rejected the lot considering 10^3 Ω as the lower limit. However, the supplier is requesting us to accept the trays, stating that there is no ESD risk with the 10^3 Ω resistance.
Could you please advise on this and confirm whether we can continue using trays with a Point-to-Point resistance of 10^3 Ω for PCBA handling and storage?
Thank you in advance.
Greeting of the day from India, to all the members on this forum.:rose:
Rahul Sir,
I love to see your postings regularly as well as from others too on this forum which keeps energizing me to remain active and providing continuous opportunity to learn in this field even at 72.
Good question indeed .This is how we can understand the practical issues faced by real users who want to use the right EPEs with proper knowledge which is very much required in the ESD control -in the electronic sector at least in India. Because even after four and a half decades of this ESD concept in Indian electronic sector still in 90 percent of the industry it is just at the grass root level with total ignorance - negligence but the industries are easily getting the label ANSI ESD S 20 20 / IEC 61340-5-1 ESD FACILITY CERTIFIED. Till date I am unable to understand the value or concept behind of this facility certification when the basic compliance is not found okay in many places.
well; coming to your question with the little knowledge I have, I would like to put up my views as under and look forward to our ESDA experts and other colleagues comments as well soon.
  1. What was the technical condition of your purchase order ?
  2. Was the sensitivity of your device you were to place inside the said EPE considered prior
    to deciding the said EPE and is not meeting your requirements ?
  3. Did the supplier supply you the said EPE with a detailed PQ test report per the applicable
    test methods or did you get the PQ test report within facility or got done from a
    third party before putting into use ?
    It is mandatory for the packaging items that it shall undergo PQ tests at 12%+/- 3 as
    well as at 50+/-5 % at temperature 23+/- Degree C prior to its use .
  4. What was the ambient condition at your EPA when you checked the said EPEs ?
  5. In general the P-P tests and Point to ground able point (Rtgp)resistance both are
    required during the PQ test and for the compliance test it is only the point to ground
    resistance which is the most critical parameter to confirm the item’s ability to
    safely conduct an electrostatic charge away from the surface to the EPA’s grounding
    system.
    6.Considering the CDM Risk, P-P e3 ohms range will be highly conductive per the ANSI/
    ESD S541 as the packaging materials that comes into intimate contact with the sensitive
    component be ideally be in dissipative range > 1 x e4 to <1 x e11 ohms .
    7.Since your observations are perhaps in the ambient conditions , compliance verification
    point of view I do not foresee anything wrong in accepting the said items provided that
    the components or devices you are placing inside these trays are normal EDS-sensitive
    items but not very highly sensitive components in CDM limits and you do not experience
    the same e3 ohms P-P through out,
  6. In case you continue to experience the same e3 ohms at lesser Rh% anytime in between
    and if you happen to place highly sensitive components in CDM limits then perhaps you
    will have no option except to reject the items under subject discussion.
  7. However, in my opinion it is better you get a detailed PQ test report from a certified lab
    per the applicable test methods per ANSI ESD S541.
  8. Because it is showing P-P e3 and Rtg e7 I doubt about the said EPEs homogeneous
    property and perhaps it is not ESD safe volume resistance wise and the surface could
    be a conductive spray coated .
    Look forward to experts comments and your comments as well .
Hello Mr. Vijay Sir,
Thank you so much for your prompt response.
These conductive trays are qualified as per the product qualification requirements at 12% ±3% RH as well as 50% ±5% RH. Currently, these trays are being used in an environment with 40% to 60% RH.
We are using these trays on a movable trolley, as shown in the attached picture.
So, could you please review the above conditions and advise whether a 10^3 ohms tray would be suitable for this application?
Thank you for your support and guidance.
Greetings of the from India, to all the members on this forum :rose:
Rahul Sir,
Thank you for your immediate feedback.
Thank you for sharing the images.
  1. What is the conclusion result in the PQ report ? As ES conductive tray or ES dissipative tray ?
  2. What was ordered by you ? As ES conductive tray or ES dissipative tray ?
  3. What were the observed parameters at 12% +/- 3 Rh ?
  4. Your image on P-P test shows that one of the probes is slightly lifted up and not
    making perfect flat contact with the entire area to cover the base of the probe.
    Could you please get it checked again?
  5. Further , both the trays looks to be different and looks to the two measurements
    are different and made on different trays .
  6. Is the test per STM 11.12 done for volume resistance check ?
    I feel doubt about its homogeneous property as the Rtg is higher to P-P.
  7. In case you continue to experience the same e3 ohms or less at 40-60% Rh only or
    at lesser Rh% anytime in between and if you happen to place highly sensitive
    components in CDM limits, then perhaps you will have no option except to reject
    the items under subject discussion provided you had specified you requirement in
    the purchase order.
  8. However, if you can pack your PCBAs inside the static shielding bags and then
    keep the enclosed packets inside the tray , it would be safe and good and no
    issue in using the trays . Further it provides the required Faraday cage protection
    also.
Anyway let me have your feed back again and meanwhile let us welcome our experts and colleague members opinion also.
Thank You & good day :rose:
Rahul,
Many companies use conductive totes and even worksurfaces successfully because they are able to control the charging of the ESD sensitive components. Remember the limits in ANSI/ESD S20.20 for worksurfaces, shelving, and mobile carts are < 10^9 ohms. There is no lower limit. There is a footnote that if CDM is a concern, you should consider setting a lower limit of 10^6 ohms, but even this may or may not be enough to prevent a CDM discharge if your ESD sensitive items have very low CDM limits and if there is no way to control charging. If you are placing the trays on a grounded cart, the ESD sensitive PCBAs are grounded when moving them into the trays, and the operators are grounded, then there is likely a low risk of a CDM discharge into the trays. If for some reason you are dealing with a very sensitive ESD item and you can’t be sure of it being grounded, you may need to move to a dissipative tray.
Thank you so much Andy Sir for your more clarity and guidance on the CDM risk.
Hello All,
Could you please suggest a thermoforming tray material that meets the surface resistance range >10^4 to <10^8ohms, static voltage <30V.
Greetings of the day from India to all the members on this forum :rose:
Hello Rahul Sir,
Well , to meet your requirement I hope the mfrs of the item may only help you as they would be knowing the exact composition of the base material and the additives they are using and the ratio they are maintaining to buildup the required ESD safe property.
While it is not an impossible issue , you may approach your supplier /mfrr. with what you require and perhaps by reducing the percentage of conductive additive and by slightly increasing percentage of the dissipative additive in the mixing ratio, they can extrude the basic sheet for thermo forming.
Even there are molded bins also available in the range greater than 10^4–10^5 ohms
and thus , it may not be difficult . By increasing the dissipative range and reducing the conductive range even the materials brittleness also reduces considerably to make it more stable against the atmospheric changes.
I look forward for our ESDA experts and other collegues veiws as well.
Thank you .
Rahul,
It can be difficult to find a molder that can consistently manufacture trays in that range. It is not an easy process to mold. Pressure, temperature, flowrate, amount of conductive material, etc. can each affect the final product. Often, a tray will have “hot spots” where the resistance can be either too high or too low. This can require quite a bit of testing of new trays to make sure they pass. It wouldn’t be a simple one-point test on each tray, but multiple points around the tray to ensure there are no hot spots. If you are looking for a new supplier, Lubrizol was recommended to me as one who is familiar with these issues.
With this difficulty in obtaining a good dissipative tray, you may want to consider a conductive tray and then look into controlling charging so there is little to no risk of putting a charged ESDS item in the trays.
Once again, Greetings of the day from India to all
Thank you Andy Sir for more detailed information.
Well , the consistency problem is always there as a regular issue even with running mats / tiles molded bins / corrugated sheets /ESD safe bags /ESD hard laminated sheets / ESD Fabric and Synthetic leatherette used for chair etc.
As you have rightly stated " It is not an easy process to mold. Pressure, temperature, flow rate, amount of conductive material, etc." and voltage variation during the process everything play its own role .Thus , as the consistency is not guaranteed but an an avg basis one has to go ahead because the standard acceptability range is too wide in the dissipative range .
Rahul Sir
Following are the few Indian Mfrs who may be contacted if they can meet your requirements.
About Us — Three Generations of Thermoforming | Indu Thermoformers
Thermoformable ESD Sheets for Custom Electronic Packaging
https://emstechnologies.in/
Thank you very much, Vijay Sir and Andy Sir, for your valuable inputs and guidance…
