System verification
Dear experts,
can you further explain what is meant by this statement?
100volts (±5%), underload for measurements of 1.0x106 ohms and above
10volts (±5%), underload for measurements from ≥1.0x104 ohms to less than 1.0x106 ohms.
Hello Rose,
These statements have to do with the internal power source of the meter and the capability of the meter to maintain the voltages required to give accurate measurements. Under load means that when you push the test button and the meter begins its electrification period, the meter will maintain the voltages stated during the time the measurement is being taken.
If the meter falls out of these ranges during your test, you will most likely have inaccurate measurement results
