Greetings, I’ve already done some research within the forum about ESD seating and classification practices. We’ve decided to classify our seating as essential insulators. As a result I’ve begun looking into qualification standards (the three bulleted points) under Section 8.3.1 Insulators. The first criteria is that the location where the ESDS item is handled must be less than 5000 volts/meter or 125 volts/inch. For the following two criteria it’s clear how to measure the voltage on the surface of the insulator, but the former isn’t clear on what device to use and how to perform that measurement. The area where the ESDS item is being handled is just a workbench with a grounded mat.
For context we already own a Keyence SK-H Series (H-050) handheld static sensor, and I would like to use this to meet the first criteria if possible. The hand held sensor can measure in units of V and V/in but based on the op manual and data sheet I couldn’t tell if this translated to charge measurement and electric field measurement.
Any information on this topic or insight would be greatly appreciated, thank you!
Great question. I would first recommend obtaining a copy of ESD TR53 Compliance Verification of ESD Control items (if you don’t already have one). It is a free download from the Standards section of the ESDA website www.esda.org.
Then take a look at Section 7.3.1 on insulators - this is a discussion and test procedures for insulators (with pictures)
Most handheld electrostatic field meters operate using a principle called electrostatic induction, typically through a sensing electrode and a vibrating or rotating chopper.
The measurement process typically works as follows:
Charged object creates an electric field. A charged surface produces an electric field in the surrounding space.
Sensor detects the field. The meter’s sensing electrode responds to the electric field without touching the object.
Field modulation occurs. A vibrating or rotating shutter (chopper) periodically exposes and shields the sensing electrode from the field.
Electrical signal is generated. The changing electric field induces an alternating electrical signal in the sensing circuit.
Signal is processed. The instrument converts the signal into a field-strength reading, usually displayed in volts or kilovolts.
The meter measures the electric field, not the actual charge quantity stored on the object.
Greetings of the day from India to all the members on this forum.and welcome to Mr. Noah to our community
A nice question and already our ESDA expert Mr. Mats has provided a very descriptive answer.
Well seating is an optional item and thus if it is not explicitly mentioned in the ESD control program plan then you are right that under Section 8.3.1 Insulators you need to look at it .
Surely, the area where the ESDS item is being handled is just a workbench with a grounded mat but, as the seating will be closer to the table edge with its handle many a times insulator it is essential to consider the criteria mentioned above and as well as the suggestion by Mr. Mats please refer to TR 53 Section 7.3.1 insulators.
