S20.20 and IEC61340-5-1
hi ESD Experts,
have some question on the two standard, is the content same? what is the difference and what is more strict?
thank you in advance!
ANSI/ESD S20.20 - 2014 and IEC 61340-5-1 Ed 2 are technically equivalent. There has been an update to ANSI/ESD S20.20 to the 2021 version. IEC 61340-5-1 is going through an update to edition 3 and will be technically equivalent. The changes between the last two additions are to the requirements for product qualification (only for new ESD control items) and alignment between ANSI/ESD S20.20 and IEC 61340-5-1 on insulator measurements.
As far as which one is more strict, both have requirements that are technically equivalent. If you comply with one, you will comply with the other.
hi John,
thank you very much for the clarification.
