Questions on ESD Practices and Safety
Hi all,
I’m new to this forum and ESD concept :grin: I’m looking to improve my understanding of ESD safety practices and procedures. I have a few questions and would greatly appreciate your insights:
  • In an EPA, if a staff member is not using certain safety measures, could this be considered a violation? For example, they are wearing ESD safe shoes and ESD safe T-shirts but are not using a wrist strap. Would this be classified as a compliance issue?
  • Datasheets for pink antistatic bags mention they are not entirely resistant to external influences. Does this mean external contact can affect the interior contents? If so, what precautions should be taken?
  • If there is a power outage, are devices connected to ground points still operational, or does grounding only ensure safety without affecting functionality?
  • Can you recommend any resources or references for understanding ESD effects at different levels, such as system-level and chip-level?
Looking forward to hearing from the experts here!
Thanks in advance! :blush:
Good evening from India .
Glad to Welcome you to the ESDA Forum and good luck .
Well my first suggestion would be to visit ESD Association site @ www.esda.org and down load the ANSI.ESD S20.20.2021 , ANSI/ESD TR 53-01-2022 and ANSI /ESD 541-2019 which are all available on Complimentary basis under the Standards heading and, you will get answers and detailed information pertaining to point 1 -3 and from news room column you will find some white papers which can perhaps answer your point 4 plus many more.
You may go through the membeship details and if you decide to become a member many of the Technical reports are also available on Complimentary basis to the members.
As far as your thrid point on power outage is concerned , to the best of my knowledge the ESD facility grounding connected to your equipment earth is basically for ESD control aids /devices /equipments you are using for ESD safety and has nothing to do with your power outage.
Our ESDA experts Mr. JohnK and Mr. Andy and others would perhaps throw more light on your topic because their experience in the field is very vast and benefiting all of us in the forum every time.
Good luck again on your joining us in the forum
Ali,
See answers to your questions below:
Question 1:
This depends on the specific EPA requirements for your facility. In your example a wrist strap may only be required for seated operations but the footwear/flooring is okay for standing operations. If your operator is never seated, a wrist strap would be optional.
Question 2:
This means that the bags do not have static shielding which is only typical in the silver shielded bags. This would mean that an ESD event outside the bag could affect the ESD sensitive materials inside because they do not have static shielding properties. The pink antistatic bags may have a conductive/dissipative resistance and may be low charging, but they will not be able to shield its contents from an actual ESD event. That is why the pink antistatic bags are only acceptable inside an EPA. Anything leaving an EPA needs to have the discharge shielding property.
Question 3:
Grounding is independent of power being on as the ground wire should connect to an earth ground
Question 4:
I would recommend looking into the various on-line and in person training offered through the ESDA’s website at EOS/ESD Association, Inc. Training & Education | EOS/ESD Association, Inc.
Hope this helps. Thanks
Thank you for the warm welcome! :blush: I already checked those documents, but I will go through them in detail. Thanks a lot for your reply! :slightly_smiling_face:
Mr. Andy, thank you for your response :blush:
I have two specific cases related to ESD safety practices, and I would greatly appreciate your expertise to clarify these issues:
Case 1:
In our ESD-safe environment, the flooring is compliant with ESD standards, and our staff wear ESD-safe clothing, smocks, and footwear. However, during PCB handling, they directly touch the PCBs with their hands instead of using a handling tool or carrier. My question is: does this constitute an ESD violation, or is it acceptable under these conditions?
Additionally, I am trying to understand how ESD footwear alone provides sufficient protection for standing operations. For instance, I tested a wrist strap by touching it to my smock, and the continuity tester indicated it was not grounding properly. This raised questions for me: if a wrist strap can fail due to layers like smocks, socks, and footwear, how does footwear effectively maintain a grounding path for standing operations?
Case 2:
To evaluate how ESD violations might contribute to PCB failures, I started counting instances of potential ESD non-compliance by our staff. Although I understand this method may not yield perfectly reliable data, I aim to identify possible correlations between ESD violations and PCB failures.
For example, when staff transfer PCBs between workstations by hand (even while wearing ESD-compliant smocks and footwear), I count this as a violation. Similarly, I monitor seated operations where wrist straps are not used. My question is: should such instances (like hand-carrying PCBs) be considered ESD violations, or are they acceptable under certain conditions?
Your insights on these practices will help me refine our procedures and better understand ESD risk management. :blush:
Ali,
First, a little background on footwear and flooring to make sure we are on the same page, then I will answer your questions. Both the footwear and flooring should be qualified separately per ANSI/ESD STM9.1 (footwear) and ANSI/ESD STM7.1 (flooring). They also need to each be verified on a periodic basis per ESD TR53 (typically daily for footwear and monthly or quarterly for flooring). The resistance limits for both footwear and flooring are less than 10^9 ohms per ANSI/ESD S20.20.
Sometimes a given footwear and flooring option do not work well together even though each may pass the resistance tests above. To ensure the footwear and flooring system work well together, both ANSI/ESD STM97.1 (resistance) and ANSI/ESD STM97.2 (walking voltage) should be used to qualify the footwear/flooring system. Each different footwear option (for example, brand of shoe) used should be tested on a given floor. The limits for these tests per ANSI/ESD S20.20 is less than 10^9 ohms and less than 100 volts.
If all this has been done, your footwear/flooring system should be acceptable for operators to handle/transfer ESD sensitive items by hand as they are grounded through their shoes and then to the flooring.
You also asked how footwear effectively transfers charge through the socks and shoes when a wrist strap will not do this if it is placed over clothing. The answer is that socks develop moisture in them as they are used and the charge is able to pass through this moisture layer and then into the shoe. Sometimes, after putting on the footwear, it will not pass the resistance test right away because not enough moisture has accumulated to create a good path for charge transfer. After walking around a while, this clears up and the footwear passes the resistance test. This would not happen with a wrist strap over clothing as a moisture layer would not typically develop in the clothing
You also mentioned observing seated operations without using a wrist strap. This would not be acceptable per ANSI/ESD S20.20 as the operator may lift their feet off the floor and remove the path to ground. If a wrist strap is not a good option for seated operation, you could also use the groundable static control garment system (basically a garment with a strap attached at the waist) to free the operator’s wrist
Hope this helps. Feel free to ask any other questions. You may also find it helpful to go through some of the training material on the ESDA website.
Andy has already covered the standards side really well, so I’ll just add a practical perspective.
For Case 1, simply touching a PCB by hand is not automatically an ESD violation if the operator is working within a properly qualified EPA. If the footwear/flooring system has been validated, the operator is wearing compliant ESD garments where required, and the grounding system is regularly verified, then handling the edges of a PCB by hand is a common and accepted practice. Of course, from a product quality standpoint, it’s still good practice to avoid touching component leads or contact pads because of contamination from skin oils and residues.
Regarding footwear, it’s easy to think of shoes as an insulator, but ESD footwear isn’t relying on the sole material alone. The complete path—from the body, through socks, footwear, and into the ESD floor—is what matters. That’s why periodic footwear testing is so important. A footwear/floor combination that passes qualification testing has already demonstrated that it provides an acceptable path for charge dissipation under normal working conditions.
For Case 2, I’d be cautious about counting every manual PCB transfer as an ESD violation. Instead, I’d separate actual non-conformances from potential risk factors. For example:
  • An operator seated without the required grounding method would generally be considered a non-conformance.
  • An operator carrying a PCB by hand within a qualified EPA while using a verified footwear/flooring system would typically be considered acceptable practice rather than a violation.
If you’re trying to correlate ESD practices with PCB failures, you’ll usually get more meaningful results by focusing on failures to follow the documented ESD control program (missing wrist strap where required, failed footwear tests, ungrounded workstations, damaged work surfaces, etc.) rather than simply counting every instance of direct PCB handling.
One thing that’s often overlooked is that ESD control is about managing risk, not eliminating every possible source of static. A well-designed EPA uses multiple layers of protection—grounding personnel, grounded work surfaces, ionization where needed, shielding during transport, and regular compliance verification. Looking at the whole system usually provides a much clearer picture than evaluating a single action in isolation.
If you’re interested in practical guidance beyond the standards themselves, there are also some useful technical articles from ESD equipment manufacturers, including Bondline, that explain the reasoning behind common EPA practices in a more application-focused way. They can be a helpful complement to the ANSI/ESD standards when you’re trying to understand the “why” as well as the “what.”
First of all, the experts at ESDA have already provided a detailed answer to your question. However, I’d like to add one more point regarding your question. When employees manually transfer PCBs between workstations, do they wear anti-static gloves? I believe there will be an ESD risk if they directly touch the products without wearing gloves.
Greetings of the from India to all the members on this platform :rose:
  • The fundamental thing in an EPA is that , all the conductive -dissipative materials (EPEs used in an EPA) and the operator are properly grounded through a common ground point to remain at the same potential.
  • Wrist straps are the first line of defense in an electrostatic control program and mandatory especially if the operator is in sitting position to ensure that he/she is properly grounded through a common ground point. This ensures that any ESSD or any PCB with ESSD handled by the grounded personnel is/are safe.
  • The Usage of gloves and garments is good but not mandatory and if used it needs to be documented in the ESD Control Program . But , when used it needs to used along with Wrist strap which is mandatory except for the Ground able Static control Garment system where the garment is directly grounded instead of grounding through a wrist strap
  • While in sitting position usage of both the wrist strap and footwear (provided the floor used is an ESD safe grounded floor ) are advised, at times the operators foot will not be directly in contact with the grounded floor and thus , wrist strap is mandatory in sitting position and footwear is mandatory in mobile condition ( if mobile on a grounded floor).
  • As per my practical observations in an EPA with a properly grounded floor and work surface with ambient Rh% above 35% @ temperature20-26^C if the personnel grounding is perfect then the body voltage is just less than max. 20-30v or even less at around Rh% 40-45%
  • Thus, under these specified conditions as long as the operators/personnel are properly grounded with the respective personnel grounding aids and not generating any static voltage greater than 100v, perhaps there is no threat if the PCBs are touched directly and, moreover while transferring the PCBs the PCBS are supposed to be handled holding the edges and not by holding the PCBs pressed between the fingers.
Thank you .
I have a question. Wouldn’t there be a risk of CDM if I handled the PCB without wearing gloves?
Sameer,
If both the PCBA and person are grounded there should be no risk of CDM or HBM as both are at the same potential. If the PCBA is grounded but the person is not, there is a risk of HBM. If the person is grounded but the PCBA is not, there could be a risk of CDM which could be mitigated by wearing dissipative gloves.
Hopefully this would not be the first choice to ground the PCBA. I think the first choice would be to ground the PCBA through the worksurface. If this is not possible, then I would try ionization. You could also attempt to ensure proper handling of the PCBA on the edges by proper training of personnel which may reduce the risk to an acceptable level at your factory.
If personnel are wearing dissipative gloves for other reasons like cleanliness, then continue to use them but I don’t see a good justification to add dissipative gloves to mitigate a CDM risk on PCBAs when better options are available.
Greetings of the day from India to all the members on this forum platform.
Mr. Sameer , , you can see that our ESDA Expert Andy Sir too has mentioned the same what I mentioned about how to handle a PCBA. Further he has clearly mentioned that you may continue wearing dissipative gloves for other reasons like cleanliness but only with just wearing dissipative gloves to mitigate a CDM risk on PCBAs is not the best option.
Further his first para is quite an important note ." If both the PCBA and person are grounded there should be no risk of CDM or HBM as both are at the same potential. If the PCBA is grounded but the person is not, there is a risk of HBM. If the person is grounded but the PCBA is not, there could be a risk of CDM which could be mitigated by wearing dissipative gloves."
Thank you Andy Sir
