We are developing a sensor that mounts to the top of a steel grain bin. The PCB contains a camera module for measuring volume of bulk dry goods (grains). The grains will flow over the sensor creating a charge that will need to be dissipated. Typically these bins could also attract lightening. Should I use ESD plastic or Conductive? Who may be able to consult in such an application?
Jim_R
For charge dissipation, conductive or dissipative plastic will work as long as they are connected to ground. For lightening protection I am not such which is better.
