I’ve read a few conflicting opinions on this topic so I’m looking for clarification. I have a fixture with a few conductive components that may contact ESD sensitive product.
The conductive material measures less than 1x10^9 ohms point-to-ground. Per ANSI S20.20, an isolated conductor is a conductor that measures greater than or equal to 1x10^9 point-to-ground.
So these components are not “isolated” conductors. From this, I’m concluding that the requirement on the +/-35 volt potential between isolated conductors and ground does not apply.
With all this in mind, are there any charged device model requirements that still need to be considered/followed? Or is this point-to-ground resistance being less than 1x10^9 enough?
Also, there is a statement in ANSI S20.20 that states: “If there is a concern for CDM failures, then a lower limit of 1.0x10^6 ohms for point to point and point to groundable point should be considered.” I don’t have any reason to be concerned with CDM failures, but was looking for clarification on if this statement might apply in situations where there’s contact between product and conductors (non-isolated conductors).
Thanks
