How do you handle ESD when installing a 43-inch smart TV in a carpeted room?
I am setting up a 43-inch smart TV in a carpeted basement room here in Minneapolis, and I keep going back and forth on the ESD side of it. The TV itself is a consumer product, not sensitive lab gear, but the room stays dry in winter and I have already zapped myself on a door handle twice this week. My concern is handling the panel and the main board during a wall-mount install, plus plugging in HDMI and power while standing on carpet. I am not sure whether a wrist strap and a grounded mat are overkill for this kind of household job, or whether basic precautions like touching a grounded chassis first are enough. I would rather not damage anything before it is even mounted. For those who do installs and teardowns at home, what level of ESD precaution do you actually use for consumer electronics like this?
I think the triboelectric series should be considered directly. See what the carpet is used. Is that wool or synthetic? The same take a look at your garment. The shoes. See, where they are in the serie. When close one to other, there is no problem with high volume of charge. Use only materials close settled down in serie. Next move slowly, never fast. Touch metal parts on TV set, touch metal parts on cables (like HDMI). Wait a moment before installation. Should be OK when you think what you are doing.
You can use wrist strap, too. But think rather about equipotential bonding and killing difference of voltages between units under installation first. Even they are powered on the smart TV or other things are often not grounded - not bonded to PE (Earth Point). It depends to design.
