Hi, please help to elaborate Ground Wrist Strap Connection (non-monitored) on ANSI/ESD 20.20?
Thanks!
Hello and welcome to the forum.
The Ground Wrist Strap Connection is where you plug in the wrist strap or connect the wrist strap to ground. In the illustration below, the wrist strap connection point is in the red circle. The recommended connection is to common point ground and then from common point ground to the ESD defined grounding system.
Hope this helps.
If you have any other question, please feel free to ask.
