I would like to ask you a question regarding the transport of ESDS material outside the EPA.
Situation should be following:
Detrash the ESDS material in EPA, put the detrashed material on to ESDS plate to ESDS cart without bag, transport the cart from Detrash EPA to Assembly EPA (red arrows direction) - the way is still on the same ESD protective floor but the way/path is outside the EPA borders.
Must we create the EPA corridor for material transport or are there any other possibilities?
I´m sharing the lay out - if we create EPA corridors as red arrows showing, the EPA will be crossing the main corridor where are motor vehicles allowed to ride - would this be some kind of issue?
I think the biggest question is whether there is an ESD risk to your product while moving it from the detrash EPA to the assembly EPA. If both EPAs are working properly, the biggest risk would be someone, who is not grounded, handling the ESDS product while in the transit lanes outside the EPA.
If you want to create EPA corridors you would need to test the floors in these areas per your ESD control plan as well as state in your ESD control plan that motor vehicles can cross this EPA corridor but may not be parked there. I think this option is more work and so I would not recommend it.
If this risk can be prevented or reduced by something like training, signage, barriers, etc., and it documented in your ESD control plan, I think you should be fine without adding special EPA corridors. You would want to make sure that your product can only leave the EPA in this way as long as it is in transit to another EPA and is not to be stored outside an EPA. You would not need to be concerned if the flooring between EPAs is within limits as the product, although it may charge up in transit, will be grounded through the floor when it reaches the destination EPA and may be handled next.
Greetings of the day from India to to all on this forum
Mr.LucieM,
Well , our ESDA expert Andy Sir has given already a good explanation and suggestion.
To enjoy exchange of ideas following are my observations & suggestions;
Looking into your explanations and the photo shared by you, it is clear that there
is an open way in between Detrash EPA & PCBA EPA which is non ESD
safe for vehicle movement. That means it is not within the same EPA .
Detrashed material moving without any protective cover and crossing an
open area at risk before reaching another EPA .
Looks like that the two EPA’s are under different roof and separated.
Thus, my suggestion for maintaining the static protection is;
to remove only the generic packaging during de-trashing but retain the components in their original ESD protection bags or foams— put them on to ESDS plate to ESDS cart until the completion of exact moment and they reach the assembly EPA. Ensure to cover the ESDS plate preferably with a conductive sheet or a static shielding film.
At both ends ( a the loading point of de trashed material as well as at the unloading point at PCBA EPA make sure that the personnel handling this entire process is properly grounded with necessary personal grounding aids and gets grounded properly at either ends before touching the material.
Lucie
Please design more shielded trolley to transport ESDS. I understood the same roof and the same floor, but only borders are separated. So, as Mr Andy said - somebody not grounded can bring the risk. And/or the big electric field generation.
