A supplier sends us a fully sealed module that complies with the Faraday cage effect, but ships it in an ESD-shielded bag.
Question:
Is there any impact or difference between shipping fully sealed products with or without an ESD bag?
The reason for this question is because they want to eliminate this ESD-shielded packaging for products classified as Faraday cage-compliant.
Yes, there is a difference between a fully sealed product in an ESD shielded bag or not. In order to adequately protest the product, it should be in a ESD shielded bag that has been tested to ANSI/ESD STM11.31 and be less than 20nJ per ANSI/ESD S20.20. I’m not sure what you mean by “Faraday Cage Compliant”. If you have a standard a supplier references for this, please let us know. Thanks
I think it would depend on how good the metal caps are in protecting your ESDS item. If it was tested to IEC61000-4-2 then I would agree that you wouldn’t need an ESD shielded bag as the ESDS item is already protected by the metal caps. If not, you would want to do some kind of testing to confirm if the metal caps work. Depending on the cost of testing, it may be less expensive and easier to continue using the ESD shielded bag. Thanks
Ready product as Andy said before should be checked for sensitivity threshold. But my first thought was why it was packed into shielding bags. Is there any connector withoud good protection? I think, yes, there is one, or more. And why they tries to remove bag. Only due to money or they have today knowledge enough? Your part should be investigated
