ESD Clean-Room ISO 7 which is EPA Zone
Hi good Peoples
We have a Clean room ISO 7. which is EPA Zone. where we need to wear a CAP to cover the hairs.
i could not find any explicitly Instruction in Standards. not not IEC neither in ANSI. can we use none ESD CAP to cover the head?
If not what are the RISK?
Can we make a Tailoring for this, with Instruction to our Operators?
Huge thanks for your always good ideas
Salaam Khassam
Khassam,
The closest thing in the standards about a cap would be an ESD garment which is an optional ESD control item usually used to reduce the risk of an electric field emanating from the body of an operator that could induce a charge on an ESD sensitive item. Since the head of an operator is usually not close to the ESD sensitive item, the chances are remote that it could induce a charge and thus a “ESD safe” cap is probably not needed. There would be no need to write a tailoring statement since the cap would, at best, be considered an optional ESD control item.
Hello
Grettings of the day from India.
As our ESDA expert Andy Sir has mentioned , Cap is under ESD garment category which is optional subject to users choice and the environment - sensitivity of your job or the device being handled.
In my opinion, the main idea or purpose of using cap/hood is for the following reasons.
  1. Most people have dry hair
  2. Most people have the habit of scratching their hair often which is a violation in an EPA
  3. Most of the Female operators often have long hair which will be another threat while at work in an EPA
    As Andy Sir has cleared , no need for any Tailoring statement but it can be included in your ESD control program plan .
    Basically the ESD control Program plan is what exactly you will follow and record the events , check and take further corrective actions if required any.
AndyN,
I truly appreciate your time and explanation which always sounds and look like a Tailoring.
Am glad that we dont need to write a Tailoring for that.
Huge thanks to INDIA as well, for your well formed expertise thoughts. I truly cherish your time guys.
Dear G N VIJAYAKUMAR
Long hair could be a safety issue in the Pland where a lot of belts and automatic lines are working. Hair can be catched and make big problem to person.
My opinion - hair must be always tied hardly and never loose strands of hair should hang freely down. There is a Plant place at first.
Greetings of the day from India to all the members on this forum.
Ireneusz (Sir/ Madam),
I truly vouch your opinion.
I refer and always recommend Caps means to cover full hair.
I consider a clean room hood with a face mask also as a cap only which can very well cover long hair for those who have the practice of not keeping it tied.
Thank you for you words of caution “Long hair could be a safety issue in the Plant where a lot of belts and automatic lines are working. Hair can be catched and make big problem to person.”
Dear Sir,
I am absolutely male :slight_smile:
You are welcome.
Sir
Sorry Sir and I apologies.
At times , on some names as I find it difficult to differentiate I put within the bracket ( Sir/Madam) to make it as applicable but not with any other wrong intention.
Thank you for acknowledging in a sportive way :pray:
