What if I am only certified in ESD 20.20 and after requesting the DataSheet to check the Product Qualification, the test method is recalling the IEC standard? Is that valid for ESD? or does the Product Qualification has to call an ANSI/ESD test method?
Good morning /afternoon from India .
IEC 61340-5-1 is equivalent to ANSi/ESD S20.20 and both are for ESD control Program and certified by ESD Association for ESD facility certification.
But , what you have referred is IEC 61850 which is the international standard for defining devices within substation automation systems and how they interact with one another.
The 61340 series of test methods and the standard test methods from the ESD Association are technically equivant. Make sure you follow the low humidity requirements from the IEC specifications. Testing to either standard should be fine.
The ESDA is the USA represntative to the IEC. The IEC committee, TC 101, works to keep the standards harmonized. Most of the IEC standards with relation to electronics can find the beginings at the ESDA.
