I work in a small electronics assembly area in Boston, and our benches are set up with mats and wrist straps, but the seating is a mix of old task chairs that nobody really chose. I spend most of the day seated at the bench doing fine work, and my back has started complaining. I am trying to decide whether to push for proper ergonomic office chairs for the whole bench row or just replace the worst ones first. One concern is that most office chairs are not sold with ESD in mind, and I am not sure whether a standard ergonomic chair on a conductive floor or mat creates any static risk, or whether the casters and fabric matter. I have only seen general furniture information online, nothing specific to our environment. Has anyone here chosen chairs for an ESD-protected area and can share what actually worked, and what to avoid? Budget is limited, so I would rather get this right the first time.
Leopoldo,
Many companies do not use ESD chairs in their factories as they are an optional ESD control item per ANSI/ESD S20.20. Their main purpose is to provide a back-up personal grounding method to wrist straps for seated operations. Unless your ESD program requires ESD chairs, I would recommend looking for the chair that would be best for your back regardless of it is an ESD chair or not.
The only other thing to be aware of with using a non-ESD chair is if it becomes an insulator that may be above the limits in ANSI/ESD S20.20. This would be unlikely if you are seated in the chair and thus suppressing any voltage from the charge on the chair, but it would still be something to measure and consider.
If you still need an ergonomic ESD chair, I believe you could find one online, but they may be expensive. You would also want to get the qualification reports per ANSI/ESD STM12.1 and also test the chair yourself at least per ESD TR53 to ensure you actually truly have a chair that dissipates charge when on an ESD floor or mat.
